Will motherboard display ports work without cpu integrated graphics - ASRock H87m Pro4 and Xeon 1230v3
magic123
Hi I am looking to build my first custom pc. It will have an ASRock H87m Pro4 motherboard with a Xeon 1230v3 cpu (which doesn't have integrated graphics).
The motherboard's description mentions things about supporting triple monitor, 1920x1200 max resolution etc. (it has 2 video ports and HDMI)
I was wondering, will I have to buy a dedicated graphics card to use the computer? Or will the motherboard's ports still work without cpu integrated graphics?
I would've liked to wait a while for graphics cards prices to depreciate, since I won't be gaming for a number of months.
Here is the motherboard: http://www.asrock.com/mb/Intel/H87M%20Pro4/?cat=Specifications
Here is the cpu: http://ark.intel.com/products/75054/intel-xeon-processor-e3-1230-v3-8m-cache-3_30-ghz
You will have to buy a dedicated card as the motherboard does not have Onboard and only uses those Video Out ports when you get a CPU that comes with Integrated graphics.
If you're looking at low end, the Radeon HD 6450 is a great card that does everything you would need except gaming really well, or a 7750-7770 would be great for running multiple monitors.
For NVIDIA I suggest a 650 Ti over a 750 if you're able to get one. They are better off for running multiple Monitors or gaming if you have a budget.
