Question Will MSI B550-A Pro Micro ATX be a good motherboard for Ryzen 5600 & RX 6600/RTX 3060?
Your URL takes me to newegg.ico, fix your URL.
Where I live PC components are very expensive here
Where is here?
I'm on a very tight budget.
Mentioning how much you have to spend alongside your currency helps us two fold.
On second thoughts, please state the specs to your proposed build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
Monitor:
Provided you don't use a badly built PSU, yes they should work but it'd be a good idea to answer the above questions as well. Though I should point out, your thread titled motherboard make and model and (partial) description are conflicting. The MSI B550-A Pro is an atx motherboard, not a micro atx motherboard, it's what the A at the end of the B550- designates. If it was an matx motherboard, the A would've been an M. That leads me to ask, which board are you actually looking at? People have been mislead with seller listed info in the past.
Your URL takes me to newegg.ico, fix your URL. "Fixed it '
Where is here? "Dhaka, Bangladesh"
Mentioning how much you have to spend alongside your currency helps us two fold. "BDT ৳110-120k"
CPU: Ryzen 5600
Motherboard: MSI B550M-A PRO AM4 Micro ATX
Local shop link: MSI B550M-A PRO Motherboard Price in Bangladesh (techlandbd.com)
Ram: 3200 Mhz Kingston fury 8GBx2
SSD/HDD: HP EX900 NVMe 500GB
GPU: Sapphire Pulse RX 6600 or Zotac/MSI RTX 3060
PSU: Corsair CX650M 80 Plus Bronze
Chassis: Montech X3 Mesh
Monitor: Samsung LF22T350 22-Inch Flat IPS Border-Less Monitor
Get a dual channel DDR4-3600Mhz ram kit instead.
CPU: Ryzen 5600
I wouldn't get that board. No cooling on the VRM area.
If you're getting an matx motherboard, get an matx chassis to pair with it.
^ That's my opinion, other community members can chime in on the matter. I'd get something that has cooling over the VRM on a board. Regardless of overclocking. We've come across many people who tend to overclock their boards eventually(if the function is there). If you didn't know, in order to get to DDR4-3200MHz, you're going to have to overclock the ram and in turn the IMC of that Ryzen processor.
Reactions: T9shuvo
"OK"
CPU: Ryzen 5600
"Ok. I will probably change that"
"I was considering this chassis because it comes with 6 RGB fans, which I thought would provide adequate airflow. Can I properly fit a Micro ATX board into this chassis? "Do I need to purchase an ATX board?"
