It won't require one to run but you should update to the latest to get the fixes for Windows security compatibilty, USB port dropout and audio glitches.Will I need a bios update?
But will my 5800x work with it?It won't require one to run but you should update to the latest to get the fixes for Windows security compatibilty, USB port dropout and audio glitches.
Did you read the previous posts? Yes, the board will work with it out-of-box but for best results that BIOS should be updated before you install windows.But will my 5800x work with it?
