Will my build work?
Will it work? Yes.
A few parts your may want to change.
Ram can be DDR3 - 1600
CPU Cooler never heard of the brand
PSU is overkill for this build
Double checked on the CPU cooler and it has decent reviews. Any reason you chose the core i7? What will you be using the PC for? If it is primarily used for gaming then you can swap out some of this hardware and save money.
