will my case fit a gtx 780
Green Chang
23
I am curious to find out if my case will fit a gtx 780. It is a cooler master elite 335 here is the pic http://www.coolermaster.com/case/mid-tower/elite-335/
i am afraid no it will not fit .....your case has VGA card length: 230mm / 9.05 inch and the smallest gtx 780 you will get is of 10.5 inches...
Actually my friend knows a bunch about this and he said it will work. i actually have a 500 watt power supply and he said it should work i also talked to my local pc place and they said it will run just fine
i have never said it will not work....... 780 requires a 42amp on 12+ rails so if your psu have 42 or more amps then it will work, just make that sure or u may either damage the card or psu or other stuff and one more thing putting the card on and running the pc dosent makes it work the test is when u play gfx intense games and the gpu comes under load it will draw much more power than normal then u may face restarts and black screens........
and that card u have shown to me just now is 10.5 inches in length i have checked if ur case has 9 inches of card clearance , there is no way it could fit.....
