will my graphics card fit with my pc parts.
MilkWookie
49
Hi, i wanted to get a gtx 950 so i can play more games but idk if it would fir in my pc. So I have a micro atx motherboard an a cpu cooler which is the Hyper 212 evo with 4 heat pipes. The cpu cooler is bigger than I thought but I'm not sure if I will be able to fit the GPu in it if I bought it. I will also send a picture just so u can get a clear view. and yes my case is big enough and will fit the gpu.
Picture of PC: https://goo.gl/photos/eKfA7ZVBNTJfMRB4A
GPU: https://www.amazon.ca/dp/B013WQCC5O/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=RP7CS2GS2T4V&coliid=I38ZSWOCYDDFPL&psc=1
Motherboard: https://www.amazon.ca/gp/product/B00VX1GGWQ/ref=ox_sc_act_title_1?smid=A3DWYIK6Y9EEQB&psc=1
CPU cooler: https://www.amazon.ca/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_1?ie=UTF8&qid=1475469291&sr=8-1&keywords=hyper%2B212%2Bevo&th=1
I would appreciate if someone could tell me if my new GPU I wanna buy will fit. thanks
you have plenty of space in your case, and your cooler will not get in the way at all, you should be compeltly good to go!, aslong as your psu can power the 950
maxalge
Champion
Ambassador
the important part is the case man
what case do you have?
MilkWookie
49
Here is my case: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119256&nm_mc=AFC-C8JunctionCA&cm_mmc=AFC-C8JunctionCA-_-na-_-na-_-na&AID=10592396&PID=3938566&utm_medium=affiliates&utm_source=afc-%zn
