Will my motherboard work with a Core I7 4790k?
synnchan
44
Hi. According to my speccy info, my motherboard is a MSI H61M-P31 (G3) (MS-7788) (SOCKET 0). I currently have a Intel Core i5 3330 @ 3.00GHz with it, and I want to upgrade to a Intel Core I7 4790k 4.4ghz 8mb Lga1150.
Will my motherboard work with it?
No. Your MB has LGA1155 socket while i7-4790K requires LGA1150.
I have to ask... how much are you willing to spend on the MB? Also, would you like it to be SLI/Crossfire capable? The size of the MB should be considered too as it depends on your case. List your system's full specifications so we can have a better overview.
Well... [strike]I guess if it's around the same price as the processor, I could buy it. I don't understand much about motherboards.[/strike] Nevermind, I just checked the price of LGA 1150 motherboards and they're not expensive at all. Just recommend me something good enough to go with the processor. (I suck with motherboards).
here is the full info:
Summary
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
Intel Core i5 3330 @ 3.00GHz:
43 °C
Ivy Bridge 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
MSI H61M-P31 (G3) (MS-7788) (SOCKET 0):
28 °C
Graphics
Monitor Genérico não PnP (1920x1080@60Hz)
1023MB NVIDIA GeForce GTX 650 (ZOTAC International):
39 °C
Storage
931GB Seagate ST31000524AS ATA Device (SATA):
43 °C
465GB Seagate Portable USB Device (USB (SATA)):
40 °C
931GB Samsung M3 Portable USB Device (USB (SATA)):
37 °C
Optical Drives
KernSafe DVD-RAM TM150 SCSI CdRom Device
Optiarc DVD RW AD-7280S ATA Device
Audio
Realtek High Definition Audio
Case and RAM? Anyway, here are my recommendations for around 150$:
https://pcpartpicker.com/product/2fYXsY/msi-motherboard-z97gaming5
or
https://pcpartpicker.com/product/NwGkcf/gigabyte-motherboard-gaz97xgaming7
