Will my ram kit work for ryzen 1800x
gsaroberts
31
Hey guys, I bought myself a
Ballistix Sport LT 64GB Kit (16GBx4) DDR4 2400 MT/s for my 6850k build and this was before ryzen came out. I have decided now to switch to the ryzen 1800x, since its cheaper and also get to invest in a better graphics card. I would like to know if I can use my 64gb kit that I bought?
The pc will be used primarily for production & not for gaming. I have a PS4 for that :)
Give me your feedback guys coz I am seriously having a dilemma on this.
Not sure where you could find an update to date list, maybe contact support to see if your current kit was added to the list, the latest AGESA update added a lot more kits to the official support list.
gsaroberts
31
thanks for the reply. I want to get the asus crosshair vi hero MB. So i looked the memory info on Mb like u said and this is what it said:
AMD Ryzen Processors support DDR4 3200(O.C.)/ 2666/ 2400/ 2133
AMD 7th Gen A-series/Athlon Processors support DDR4 2400/ 2133
so what do u think? i am sorry i not very tech savy when it comes to these things :)
ShadyHamster
Here's the Memory support list:
http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM4/CROSSHAIR-VI-HERO/CROSSHAIR-VI-HERO_DRAM_QVLforAMDRyzenProcessors_0316.pdf
Check out the exact model number for your kit, it should be on the sticks of ram.
The only 16GB kit i see is - BLS16G4D240FSB.16FBD(XMP)
If you kit matches that then you are good to go.
That list was last updated on the 16th of March which is now quite out dated.
The latest BIOS version is from the 15th of May, so even if your kit isn't on the support list it might have been added with this latest BIOS.
gsaroberts
31
thank you! :)
i just had a look at it and u are right, and i am stuck in the water shit!! i will have to get new sticks and this sucks big time!!! bro where can i find the latest list for the vendors, so know what i should be getting. i cannot find it on the site coz i am looking for 64 gb kit to work on 4 slots.
