Question Will my system be able to play at 144fps
GrappleBois
Commendable
Feb 19, 2019
21
Setup:
Ryzen 5 2600 CPU
Gigabyte geforce gtx 1060 6gb oc edition
MSI B450 Tomahawk ATX Mobo
2 x 8gb corsair vengeance LPX ddr4 3000mhz
Evga 500w psu white rated
I know the answer is probably no but i still want to make sure. Can i play at 144fps if i play on LOW settings on: Overwatch, R6, Apex legends or should i just stick to my 60hz monitor
Short answer: Maybe.
Long answer:
FPS depends completely on a game and it's graphical settings. Also, some games have FPS limit on them where no matter the hardware you have, game will not run faster than 30/60 FPS.
Should you go with 144 Hz monitor? Yes.
Even when you may not get 144 FPS on all games (which is unlikely since you're willing to reduce graphics and you have good GPU), you'd still get much smoother gameplay compared to 60 Hz monitor. Seeing 100 FPS or 120 FPS out of a game is still much better than playing it on 60 FPS.
My Skylake build has similar specs to your PC and i have 144 Hz monitor as well (full specs with pics in my sig). Here's the FPS i've gotten in some of the games that i've played;
55.6 FPS - Euro Truck Simulator 2
62.6 FPS - MudRunner
108.9 FPS - Astroneer
121.77 FPS - Hasbro's Battleship
123.02 FPS - Flower
Note: all games are in high/ultra settings @ 1080p fullscreen and average FPS is listed (used NZXT CAM FPS Overlay to get the FPS values).
