Will my system run GTA IV?
I1P
20
So i have an intel(R) core (TM) i7-2630QM CPU @ 2.00GHz processor and a Nvidia GeForce GT 540M gpu on my sony vaio laptop, i was just thinking of buying gta iv but i'm not sure will my sytem be able to run it.. btw the laptop is sonys vpcf21z1e, if that info helps
I looked at the requirements for GTA IV and I also took a peek at your laptop at Amazon. As far as I can gather, your system should be able to run GTA IV. I can't promise that you'll be pulling 60FPS @ 1080p under the highest graphics settings though. Your graphics card meets the minimum requirements but not much more.
Well thanks for a quick answer, low graphics will be okay. Can you roughly say how much fps i'll be getting on low graphics and maybe the resolution a bit lower?
