Will my system run Planetside 2
cgibb_01
5
PlanetSide 2 Current Minimum System Requirements:
OS: Windows XP
Processor: Intel Core 2 Duo E6850 or higher / AMD Phenom II X2 or higher
Memory: 4 GB RAM
Hard Drive: 15 GB free
Video Memory: 256 MB RAM
Video Card: nVidia GeForce 8600 series or higher / AMD or ATI 4850 series or higher
Sound Card: DirectX compatible
PlanetSide 2 Current Recommended System:
OS: Windows 7
Processor: Intel i5 processor or higher / AMD Phenom II X6 or higher
Memory: 8 GB RAM
Video Memory: 1,024 MB RAM
Video Card: nVidia GeForce 500 series or higher / AMD HD 6870 or higher
My Specs
OS: Windows 7
Processor: Amd Athlon II X 4 630 processor (2.8 ghz)
Memory: 10 GB Ram
HD: 640 GB Free
Video Card: Nvidia Geforce 560 TI
Sound Card: DirectX Compatible
Do you think I'll be able to play planetside 2 (not necessarily on high but maybe low/medium with good fps (little - no stutter)
Well your system is better than the recommended system(the CPU is not nearly as important as the GPU) so yes,unless you are running at crazy high res you wont even need to set everything on low.
