Will my system run VR okay?
Meets or exceeds the recommended specs so it should run fine:
https://www.oculus.com/rift/
Recommended Spec
Graphics Card: NVIDIA GTX 1060 / AMD Radeon RX 480 or greater
Alternative Graphics Card: NVIDIA GTX 970 / AMD Radeon R9 290 or greater
CPU: Intel i5-4590 / AMD Ryzen 5 1500X or greater
Memory: 8GB+ RAM
Video Output: Compatible HDMI 1.3 video output
USB Ports: 3x USB 3.0 ports plus 1x USB 2.0 port
OS: Windows 7 SP1 64 bit or newer
-Wolf sends
Recommended Spec
Memory: 8GB+ RAM
-Wolf sends
It's all well and good meeting the specs but it also depends on the games you will play, if they not that well coded it may suffer on your end, but then u won't know till you try, one more thing, if u are willing to spend the money for the rift would it not be a good idea to save more and up the specs of the pc aswell ?
Brett here makes a good point. Some of the games for sale have higher minimum specs than the Oculus itself.
