Will not reboot after Repair
robin
246
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Because of a problem with "Search", which was not working, I decided
to run a repair (following the regular repair option offered) from the
XP intallation disc. But now, after the repair, Windows will not boot.
I get the screen telling me to use the last successful installation
and with options also to start in Safe Mode. None of the options work.
All come back to the same screen again.
I decided to reinstall XP on a different partition, which I have now
done, so I can work. But I would like, if possible, to get the old
installation booting again. Any suggestions?
TIA.
Robin
Had you installed Service Pack 2? If so, you may need to use the Recovery
console to uninstall SP2 on that partition.
http://support.microsoft.com/default.aspx?scid=kb;en-us;875350 This takes
awhile but is generally straightforward. If it looks like nothing is
happening, give it some time.
Patty MacDuffie
www.computerhaven.info
<robin@despammed.com> wrote in message
news:45vup09htnh0ud5eoh2kulnqt0s0r7uvdt@4ax.com...
> TIA.
> Robin
On Sat, 20 Nov 2004 10:07:58 -0800, "Patty MacDuffie"
Yes I had. But I can't uninstall it. I tried using the methods on the
site, which meant using the uininstall file--I couldn't boot to try
the others--but it isn't there.
Should I reinstall on top of my old installation? Or should I give up
and format the partition? (I have copied all documents to another
partition.)
One more question. To delete the new, temporary, installation do I
just do that--delete it? What about the boot menu, which I'll no
longer want once I get back to a single intallation?
TIA
Robin
If the recovery console uninstallation did not work, first boot into your
parallel installation and copy all of your documents and other data files to
a CD or other storage device. Then you'll have to reformat and begin clean.
That will mean that you won't have SP2 and you'll have to install that
again. Do so before installing all your programs so you don't waste a lot
of effort if you run into the same problem. But before you attempt the SP2
install, go to your manufacturer's website and download any patches they
suggest for prior to SP2 install. Make sure no programs are running when
you do the installation. It would be best to install it from a CD if you
have one. Make sure your antivirus background protection is off, and unplug
any always on Internet connection as well. Good luck, Robin.
Patty MacDuffie
news:e4bvp05kug5fhu00te8jjadht0j3iv60nr@4ax.com...
> partition.)
> TIA
> Robin
Thank you very much for your advice Patty.
I already have a complete backup on an external hard drive but the
other recommendations were new to me. I had hoped to avoid
reformatting if possible, but at least it will get rid of the minor
bugs which led me to attempt the repair in the first place.
Best
Robin
On Sat, 20 Nov 2004 18:29:50 -0800, "Patty MacDuffie"
In the end I reinstalled on top of my old XP without formatting. With
a little careful renaming of files in Documents and Settings I was
able to keep a lot of my old settings.
>Best
>Robin
That's good news, Robin. So is everything okay now?
Patty MacDuffie
"Robin" <robin@despammed.com> wrote in message
news:6at3q0ttelldh890uf8nh8r41crls06qb0@4ax.com...
>>Best
>>Robin
>>>to
>>>clean.
>>>lot
>>>SP2
>>>unplug
