Will OCing my CPU help
Pro Gamer10
60
hey guys my previous motherboard and processor roasted and i bought a used amd a4 3400 apu 2.7ghz my 6 gb ram and a gtx 750 ti 2gb card and i,m getting a very huge bottleneck that fifa 16 is only giving 15-20FPS , GTA 5 15-30FPS etc so i was wondering i could reduce the bottleneck my overclocking my cpu to 3.2 ghz so will it help??? i,m not buying new stuff at the moment thanks....
I have a laptop with an A6 that's seven years old at this point. It's more powerful than my 2004 build, but my Surface tablet blows it out of the water.
Your A4 is weaker than my laptop's A6.
MERGED QUESTION
Question from Pro Gamer10 : "Will OCing my CPU help"
The moderator merged your threads because you posted the same thing twice.
What motherboard do you have? You should be able to overclock it if you want but I doubt it will do much for you. That is a very weak cpu and its not going to be very good for gaming with or without an overclock.
No amount of ocing is going to fix your problem. The a4 is extremely weak and no where near min spec for those games.
