Will replacing Corsair 500R side panel with Window raise temps?
xxxlun4icexxx
519
5
11,065
Hi,
I have a corsair 500R case right now and I hate the mesh side panel. I heard there is a replacement window DIY kit for 50.00 you can get, however I'm just wondering if doing that will raise the temps too high in the case. I have 2 140mm fans on the side panel right now so I'd be giving them up. I have a 120mm noctua exhaust at the back top, and 2 120mm noctuas in front of the drives (the top 2 are from the corsair h100i).
The CPU does not get hot currently.
I have 1 1080 right now that runs about 67-68C under full load with 60-70% fan speed. However I am looking to SLI 2 cards, so I am wondering if that will be too much heat with just a window on there.
Any ideas on how that may affect it?
Thank you,
Side windows mostly affect the gpu load temperatures by about several degrees (mileage may vary).
https://www.pugetsystems.com/labs/articles/Side-Panel-Fans-Are-They-Worth-It-102/
This test showed a 12C difference between no fan vs 120mm fan.
If you can deal with more noise / higher gpu temps with a windowed case, by all means go for it. A lot of folks eventually look for water cooling if they go for windowed cases for noise/temp reduction.
