Z ZW____ Honorable May 10, 2017 49 1 10,535 Oct 25, 2019 #1 will the x470 taichi handle the 3900x on stock settings and will it be able to overclock the cpu fine?
Solution Barty1884 Oct 25, 2019 Yes, the X470 Taichi is more than up to the task -- You'll need a BIOS update, of course.
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Oct 25, 2019 Solution #2 Yes, the X470 Taichi is more than up to the task -- You'll need a BIOS update, of course. Reactions: ZW____ Upvote 1 Downvote Solution
Encryption+ Upstanding Sep 26, 2019 330 62 340 Oct 26, 2019 #3 Yes that motherboard should be fine. Upvote 0 Downvote
