Hi guys
... I'm looking to buy the " Thermaltake BlacX 2.5”/3.5” Sata I/II/III USB 3.0 external Hard Drive Enclosure Docking Station ST0005U " with the esata port on the back.. I know I know, it's a rather old dock compared to the newer stuff out there but the people on the forum for Direct TV (looking to basically attach a hard drive to my DVR for extra space for tv shows recordings
) insist it's the best device for this sort of thing, bar none, based on their previous experience.
Here's my concern... the dock comes with a silicone sleeve presumably to keep dust off it since it's a "bare drive exposed to the air" being a dock (trying to avoid enclosures which the people on the same forum above insist are a headache when you're connecting them to direct TV DVR's and I've experienced the enclosure problem myself personally).
I'm tempted to put the silicone sleeve on there to keep away dust.. but I'm worried about it building up heat on the hard drive since the hard drive is enclosed by the silicon sleeve continuously (the hard drive will be on 24/7 , using a seagate skyhawk hard drive designed for continuous use of that nature)...
Has anyone tried operating a hard drive for long periods of time with a silicone sleeve on it? And if so has it created any problems for you?
Thanks to anyone reading this for your time and attention !
