Question Will single stick 32 GB work?
Go to Gigabyte's website and look for the motherboard manual.
The manual should provide 1) a list of supported RAM sticks and, 2) the supported RAM configurations.
The manual will likely suggest that you visit Gigabyte's website for more up to date information. So do that as well.
Yes, that is what I have done and the mb supports the 16 GB stick but the 32GB stick isn't in the list.
I reckon it means either that the 32 GB stick isn't supported, or the list isn't updated or any other reason. I mean there are sticks that works on a mb although they are not on the combability list of the manufacturer.
I find it strange that the 16 GB would work but not the 32 GB when they are the same manufacturer and type.
Could it be that the mb doesn't support 32 GB sticks at all? Have to look that up I suppose :)
EDIT: The mb supports 48 GB sticks. In the combability list there is no 48 GB stick...hmmm.
https://download.gigabyte.com/FileL...1102_e.pdf?v=b780b54385d6d39b90d6a3862d742bba
Ryzen is very picky about ram.
Save yourself a headache and buy only an explicitly supported kit for your motherboard.
Either on the ram QVL list for your processor or from a ram web site support list.
And... a single stick will be slower in single channel mode.
I have a KF556C36BBE-32
https://www.amazon.se/dp/B0BRTK24SY?ref=ppx_yo2ov_dt_b_product_details&th=1
and I need a new mb. I am thinking of Gigabyte A620M GAMING X and I am looking at compablilty. According to the compability list KF556C36BBE-16 will work but I cant find KF556C36BBE-32.
What do you guys think? Do I dare to try the Gigabyte and hope my single stick will work or not?
Best regards,
Martin
For what it's worth.
https://pcpartpicker.com/products/memory/?compatible_with=fMcgXL
