Will the Cooler Master Hyper 212 EVO fit in this case?
Ahmed1997
Hello i just wanted to know is the Cooler Master Hyper 212 EVO will fit in my cmp 103
Dimension (W x H x D)183 x 424 x 397mm / 7.2 x 16.7 x 15.6 inch
Heat Sink Dimensions 116 x 51 x 159 mm / 4.6 x 2.0 x 6.3 in
i think it will fit
what do you think guys??
159 mm is 6.25 inches. The mother board, plus stands, plus heatsink may be cutting it pretty close.
Here is an alternative that is only 125 mm, is comparable in price, and has excellent reviews: ZALMAN CNPS9500
I think it'll fit. I know the clearance says 156mm and the cooler is 158 but we are talking a difference around 1%. I'd go for it and return it if there is noise.
Are you overclocking the CPU? If not then any small fan/heatsink will do. If you want a good overclock (and have an overclockable CPU and mobo) then maybe liquid cooling like a H80i or H60.
According to Coolermaster's website for the CMP 102, the max height is 156mm or 6.1 inches.
http://www.coolermaster.com/case/mini-tower/CMP-102/
The Coolermaster Hyper 212 Evo will not fit!
I love how when you translate the link for the case the OP gave us it stats : Maximum Compatibility
CPU cooler height limit 159mm
Then you google the CM Hyper 212 Evo and it states: Heat Sink Dimensions 116 x 51 x 159 mm (4.6 x 2.0 x 6.3 in)
If what Coolermaster has written on it's websites is correct there shouldn't be a problem.
You'd waste your own money to prove that then?
