Will the EVGA SuperNova G2 1300w work with my PC?
dRCY
I want to install the EVGA SuperNova G2 1300w on my PC.
http://www.evga.com/Products/Product.aspx?pn=120-G2-1300-XR
I want to install it with the HD 7990, specifically this model.
http://www.scan.co.uk/products/6gb-xfx-radeon-hd-7990-6000mhz-gddr5-28nm-gpu-950mhz-boost-1000mhz-4096-cores-dual-link-dvi-i-mdp-pl?utm_campaign=2013%252f10%252f18+-+Scanoffers344&utm_source=scanshot&utm_medium=email
My mobo is the Gigabyte GA-Z77-D3H Intel Chipset
http://www.gigabyte.com/products/product-page.aspx?pid=4140#ov
If anyone could help that would be great, as I am unsure whether to buy or not.
edit: I know the 1300w is overkill, but its cheap and if in the future I want to crossfire I won't have to replace the PSU. Will a large power supply damage the system?
Yes, it will work for your system, however it's a bit of overkill unless you intend to have 3+ graphics cards installed and are going to do a lot of overclocking. If you only intend to use 1 or 2 video cards, and do minimal or no overclocking, you'd be fine with a 900-1000W PSU (and maybe less than that).
