Will the Hyper 212 Evo fit in a CIT Vantage Midi case?
10 days late but, it did fit in there. However, I had to remove the side panel off. Which kinda looks a bit messy. In the end, I bought a new case, the Zalman Z11 plus. The glass window allows taller cpu coolers such as the hyper 212 evo.
Hey man, I have the same case (vantage), literally just bought it, so I really don't want to have to buy another case. When you say you had to take the side panel off, I'm guessing that was because it wouldn't fit physically? I've done some measuring and it would appear to fit in my/your old case. The top fan on the side panel might have to be removed possibly however? Can you expand at all on that?
