Will the Motherboard and Graphic card match?
Lampokosa
130
Will these ones work?
Motherboard:ASUS B85M-G, Socket-1150 m-ATX, B85, DDR3, 1xPCIe-x16, VGA, DVI, HDMI, Haswell
Graphic card:Crucial DDR3 BallistiX Sport 1600MHz 8GB 8GB kit(4GBx2), CL9, 1.5V, CL9-9-9-24
Also, I don't know if it matters but does the CPU also match?
Intel Pentium G3220 Socket-LGA1150, Dual Core, 3.0GHz, 3MB, 54W, HD Graphics, Boxed w/fan, Haswell
What you have listed is not a graphics card but instead RAM. According to the CPU support list on ASUS website, the CPU you have chosen should work with that motherboard.
I would advice you look here https://www.asus.com/Motherboards/B85MG/#support for more information on your motherboard like supported RAM, etc...
Also as long as you have a modern PCIe-X16 graphics card it should work with your motherboard. Double check power requirements and space requirements in your case.
Oh, I'm sorry I forgot about the graphic card, here it is:
ZOTAC GeForce GTX 750 1GB PhysX CUDA with F2P coupon : Heroes of Newerth, Path of Exile, Warface
