[SOLVED] Will the Noctua NH-D15 fit in my case?
Oct 13, 2020
9
So my case is this:
Antec Nine Hundred
Does anyone know if the Noctua NH-D15 will fit inside of it?
Upgrading to an AMD 5800X in Nov, but wondering if I'll need a new case for this cooler?
I'm guessing you're referring to the Scythe Mugen 5 Rev.B:
https://www.amazon.com/Mugen-Rev-CPU-Cooler-Support/dp/B06ZYB8K77
It's a great budget performer, but overclocking won't be a great idea on it.
A much better option would be the Scythe Fuma 2(it's the same height as the mugen @ 154.5mm):
https://www.amazon.com/Original-Design-Towers-Cooler-SCFM-2000/dp/B07QMK5R45
There's not really much information on the Antec 900 case, but from what I've found ~160mm would be the max CPU cooler height allowance.
If you want more cooling performance, you might want to check the Noctua NH-D15S here:
https://noctua.at/en/nh-d15s
It's 160mm tall and performs similarly to the NH-D15 with a single fan.
Just to make sure, is this the case?
https://antec.com/product/case/nx300-black.php
If so, the NH-D15 is 165mm tall with the fan mounted: https://noctua.at/en/nh-d15/specification
From the specifictions page of the Antec case:
Max CPU Height≤ 165 mm
So, it should technically fit in there. You might need to run with the single central fan if your RAM modules are too tall... that shouldn't affect cooling performance much though.
No, the case I linked is the case
But I've had another reply somewhere and apparently the case only supports up to a 160mm CPU,
They recommended this as an alternative to the NH-D15:
Cooler scythe 5100smg
Any opinion on this?
