Will the Noctua NH-D15 fit in the silent base 800?
DrHerbst
37
Max cooler height is 167mm and the cooler is 165 mm high, i am not sure if it will fit or if the air flow will be affected
That is very tight. It should fit, but it will not be quite as efficient. Have you considered the almost as good NH-D15s?
It comes with 1 fan instead of two, but if you have room in your case you can add the 2nd fan.
NH-D15S NH-D15
Width (without fan) 150 mm 150 mm
Depth (without fan) 135 mm 135 mm
Height (with fan) 160 mm 165 mm
Width (with fan) 150 mm 150 mm
NH-D15S NH-D15
