Hoping someone with this setup will be able to give me some advice regarding compatibility. Will the Noctua NH-U12S CPU Cooler fit into my CORSAIR 300R case with High profile ram in the 2nd and 4th slot. I don't mind if it covers the 1st slot, just hoping it will fit the width (top) not hitting the roof fans and the other side (bottom) the graphics card. Measurements of the CPU cooler are below.
I'm also using the ASROCK FATAL1TY KILLER Z97x and wondering if all the heatsink around the cpu with block the fan.
Thanks
Height (without fan) 158 mm
Width (without fan) 125 mm
Depth (without fan) 45 mm
Height (with fan) 158 mm
Width (with fan) 125 mm
Depth (with fan) 71 mm
Weight (without fan) 580 g
Weight (with fan) 755 g
Thanks
