Question Will the NZXT Signal HD60 Capture Card work on my MacBook ?
joejackson700
Commendable
Dec 21, 2020
58
I have a MacBook Air 1.6 GHz i5, 8 gb of RAM at 2133Mhz Laptop lpDDR3
Can it run an NZXT Signal HD60 Capture Card ?
To Admin : The site's text is too zoomed-in. Makes scrolling annoying.
The website only makes mention of PC / Windows 10, 11 as far as System OS is concerned.
I would recommend either reaching out to NZXT and asking them directly as not everything compatible with Windows is compatible with Mac. It does run off USB-C so that is a plus. Do you have a USB-C slot on your Macbook?
UPDATE #1:
It appears that the Signal 4K30 is compatible with Mac but does require USB 3.2 Gen 1.
UPDATE #1:
In my system settings it says I have a usb 3.0 and a 3.1. These are the numbers for the 3.1 -
USB 3.1 Bus: Host Controller Driver: AppleUSBXHCITR
PCI Device ID: 0x15ec
PCI Revision ID: 0x0006
PCI Vendor ID: 0x8086
Bus Number: 0x00
