Question Will the ryzen 5 2600 work with the H310M PRO-VH PLUS
Sep 18, 2019
32
I want to upgrade the cpu sometime because the current one has 4 cores 4 threads and the ryzen one has 6 cores 12 threads
That motherboard only supports 8th & 9th generation Intel CPU’s. A move to Ryzen will need a new motherboard. Also what RAM do you have?
What cpu do you have now? What do you use the pc for? What’s the full pc spec? What’s the budget for an upgrade?
Sep 18, 2019
32
well its a budget gaming pc i got pretty cheap for like 515 euros
the specs are:
MSI H310M PRO-VH PLUS
Intel® Core i3-9100F
Xilence - XC032 I250PWM CPU Cooler‎
Radeon RX580 8GB GDDR5
1x 8GB DDR4-2666MHz CL16 Crucial Ballistix Sport LT
Corsair VS450
— 450 Watt 80 PLUS®
ssd Patriot Burst 240GB‎ SATA3 read/write 555/500 MBps, 3D NAND Flash
hdd 1TB Seagate Barracuda 7200RPM 64MB Cache
Case Zalman i3 Simple Design ATX
Also quick question if i would upgrade the CPU which cpu should i get so i dont bottleneck my rx 580?
