Will there be a problem if i exceed the FAN speed of my GTX 260?
Antonioj1015
9
I have a BFG GTX 260, i have heard that this video card has a fan speed problem, i have the Nvidia Control Panel in which theres an option in which i can adjust the GPU fan speed, i have seen that if i raise the speed of the fan it starts to sound loud and i am afraid that it might push the limits of the video card, so please tell me i dont want this video card to colapse...Thanks
Yes i have it when is at 80 degrees to go 100% and when is 50 degrees to go 40%
So then it's like automatic? When it is under load then it is at 100%, but if you have it at 100% a lot. Like Shadow said, it will shorted fan speed.
If your fan is at that % a lot then I would recommend improving airflow in your case to try and prevent it working that hard as much.
