Question Will Thermal Grizzly Kryonaut Work With Ryzen 7 And Stock Cooler?
Feb 24, 2019
19
I'm thinking of upgrading my CPU up to a Ryzen 7 1700 as they are only around 140 pounds. I was wondering if the Thermal Grizzly Kryonaut would work with the CPU and stock cooler as i've seen other thermal compounds which can react with the aluminium?
When you hear about reacting with aluminum its almost in reference to liquid metal. I personally don't know of a normal thermal paste that can has negative reactions with aluminum.
Anyway it will work but it's also one of the more expensive pastes and personally on a stock cooler its not worth the money since the temps you will be at could easily be done with a cheaper paste.
