checkm8156 Reputable Nov 10, 2015 7 0 4,510 Jan 7, 2017 #1 I'm pretty sure these antennas will work with my motherboard but I want to be sure before I buy them. Thanks!
Solution kanewolf Jan 7, 2017 They look correct. Your range or speed may decrease because you are burying your antennas behind your case.
kanewolf Titan Moderator May 29, 2013 38,354 3,663 156,790 Jan 7, 2017 #2 The antenna that came with it will probably work better. Upvote 0 Downvote
checkm8156 Reputable Nov 10, 2015 7 0 4,510 Jan 7, 2017 #3 kanewolf : The antenna that came with it will probably work better. I know.. but I'm asking if they'll fit. I have to switch where I game every week for a week at a time and I want something that is always attached. Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,354 3,663 156,790 Jan 7, 2017 Solution #4 They look correct. Your range or speed may decrease because you are burying your antennas behind your case. Upvote 0 Downvote Solution
checkm8156 Reputable Nov 10, 2015 7 0 4,510 Jan 7, 2017 #5 kanewolf : They look correct. Your range or speed may decrease because you are burying your antennas behind your case. Thank you! I understand the speeds may be slower. Upvote 0 Downvote
