M Mrsemexter Reputable Dec 6, 2014 2 0 4,510 Dec 6, 2014 #1 Hi just wondering if these parts would fit together
M Mrsemexter Reputable Dec 6, 2014 2 0 4,510 Dec 6, 2014 #2 Hi I was wondering if these parts would fit together, and also if you think there are any parts that you think I should upgrade? Thanks! Corsair CC-9011030-WW Carbide Series Air 540 ATX High Airflow Cube Performance Windowed Computer Case - Black https://www.amazon.co.uk/dp/B00D6GINF4/ref=cm_sw_r_awd_iWHGub111B95H Corsair CP-9020062-UK RM Series RM1000 80 Plus Gold 1000W ATX/EPS Fully Modular Power Supply Unit https://www.amazon.co.uk/dp/B00FLVIQQ8/ref=cm_sw_r_awd_OWHGub13STDYK Corsair CMK16GX4M4A2666C16 Vengeance LPX 16GB (4x 4GB) 2666MHz CL16 XMP 2.0 DDR4 High Performance Memory Module - Black https://www.amazon.co.uk/dp/B00NMJJXU4/ref=cm_sw_r_awd_7WHGub1JM46S7 WD Caviar 3TB SATA 6 GB/s 64MB Cache 3.5 inch OEM Internal Hard Drive Green https://www.amazon.co.uk/dp/B004RORMF6/ref=cm_sw_r_awd_uXHGub1XCVFV0 Corsair Hydro Series H100i All-In-One 240mm Digital High Performance Rad Liquid Cooler for CPU https://www.amazon.co.uk/dp/B009ZN2NH6/ref=cm_sw_r_awd_SXHGub1VC19AW Intel i7 5960X Extreme Octa Core CPU Processor (3.0GHz, 20MB Cache, 140W, Socket 2011-V3) https://www.amazon.co.uk/dp/B00N1O4RRY/ref=cm_sw_r_awd_bYHGub0F2A64K Asus STRIX-GTX980-DC2OC-4GD5 256 Bit Nvidia Gtx 980 Graphics Card (4GB, GDDR5, Dual Link, PCI Express) https://www.amazon.co.uk/dp/B00O11Z0H2/ref=cm_sw_r_awd_GYHGub1NG8X29 Samsung 840 EVO 250GB 2.5 inch Basic SATA Solid State Drive https://www.amazon.co.uk/dp/B00E3W1726/ref=cm_sw_r_awd_0YHGub1RN5B3M Asus DVD-RW Drive (DRW-24F1ST/BLK/AS, S-ATA, DVDR: 24x, CD-R: 48x, E-Green, Disc Encryption II) https://www.amazon.co.uk/dp/B00BZF31UU/ref=cm_sw_r_awd_iZHGub0H8MDTQ Asus RAMPAGE-V-EXTREME Intel Lga2011-V3 X99 M.2X4 SATAe Motherboard https://www.amazon.co.uk/dp/B00N98RWOC/ref=cm_sw_r_awd_zZHGub06EVSRJ Upvote 0 Downvote
H Heskey Honorable Aug 15, 2013 99 0 10,630 Dec 6, 2014 #3 Hi mate use this site to check whether your parts are compatible : http://uk.pcpartpicker.com/ . Upvote 0 Downvote
