[SOLVED] Will these pc components work well together?
Ok, Sweden.
Couple of things that could be better. For one, you don't want that Founders edition card unless you plan to use a custom loop cooling solution on the graphics card. They do not have the performance of the the aftermarket cards.
That BeQuiet cooler is not a great choice. BeQuiet does not have terrific performance on any of their CPU coolers. They are good on noise levels, but that is because they run their fans at lower RPMs which affects cooling performance. There are almost always better options at any price point than BeQuiet. Thermalright (NOT Thermaltake), Noctua, Phanteks, Cryorig and Scythe all have some good coolers available.
The Vengeance RAM isn't as good as the Trident Z memory. Get your RGB fix elsewhere OR...
Ok, Sweden.
The Vengeance RAM isn't as good as the Trident Z memory. Get your RGB fix elsewhere OR pay a little more for the G.Skill RGB modules.
The Eclipse case doesn't even look to be available in your region.
I'd probably do something similar to this, but of course you may wish to tailor it based on your own preference and budget. And yes, there are options in the top right corner on PC Partpicker to change for different countries.
CPU: Intel - Core i5-8600K 3.6 GHz 6-Core Processor (kr2990.00 @ Dustin Home)
CPU Cooler: CRYORIG - R1 Ultimate 76 CFM CPU Cooler (kr908.00 @ Dustin Home)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard (kr2249.00 @ Dustin Home)
Memory: G.Skill - Trident Z 16 GB (2 x 8 GB) DDR4-3200 Memory (kr1908.00 @ Dustin Home)
Storage: Samsung - 860 Evo 250 GB 2.5" Solid State Drive (kr740.00 @ Dustin Home)
Video Card: EVGA - GeForce GTX 1070 8 GB SC GAMING ACX 3.0 Black Edition Video Card (kr5799.00 @ Dustin Home)
Case: Fractal Design - Define R6 Blackout TG ATX Mid Tower Case (kr1599.00 @ CDON)
Power Supply: SeaSonic - FOCUS Plus Gold 850 W 80+ Gold Certified Fully-Modular ATX Power Supply (kr1399.00 @ CDON)
Total: kr17592.00
Generated by PCPartPicker 2018-12-03 04:55 CET+0100
