Will these PC parts work together?
PCNOOBHELP
29
Hello to everyone kind enough to help.
I have decided to build a gaming PC for around 750-950$ budget. I have devised a list of components, but I am not completely sure if this will work together, could you tell me if it will? If not could you suggest replacements please, staying around budget.
I am also hoping you will be able to tell me if the system would be able to run games like Arma 3, Battlefield 4, Rome 2:Total War, Shogun 2:Total War, Assassins Creed 4, Watch Dogs, The Witcher 3, etc. with at least a comfortable 40 FPS in high/ultra settings.
- Motherboard= Asus z87-C LGA 1150 - 134.49$
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131982
- CPU= Intel Core i5 4670K (Quad-Core, DDR3-SDRAM) - 239.99$
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
- GPU= Nvidia GTX 760 (2GB GDDR5, 256-bit) - 259.59$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125466
- RAM= 8GB (2x4) Corsair Vengeance (1600mhz DDR3-SDRAM) - 84.99$
ttp://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
- Hard Drive= Seagate Barracuda 1TB, (7200RPM, 64mb cache, SATA 6GB - 69.99$
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
- Optical Drive= Asus DVD-Writer Back SATA Model - 19.99$
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135305
- PC Case= Cooler Master Elite 431 plus ATX Mid-Tower - 54.99$
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119256
- PSU= Rosewill Stallion RD700w ATX 12V v2.3 SLI ready Crossfire ready - 64.99$
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182278
Prices come from newegg.com - total price would be $929.02
Thank you in advance, PCNOOB out.
P.S. I edited the post, and changed the PSU with the advice from Moonsfang, so now if anyone can confirm. Will this work with the rest of the pieces?
Good build. You shouldn't have any problems on high settings with a good fps. The only thing I would do different is replace the psu if you plan to overclock and or SLI. Antec is a good brand you just might need a 700W if you plan to SLI or OC
Moonsfang
258
