Will these work together?
Laxi
Hi! Will these parts work together and will the Power source be enough?
Case: CoolerMaster HAF922
Motherboard: P8P67 Deluxe, Rev 3.0 LGA1155
CPU: i5 2500k LGA1155
Blu-ray combo drive
2TB,1TB HDD
64GB SSD
Wi-Fi card: DWA-547, Wireless N PCI, draft-802.11n
Power:CoolerMaster 750W GX, ATX-powersource, 80Plus
GPU: GeForce GTX 580
Thanks for your time
Those parts will work fine. However I notice you did not list the RAM you are looking at buying. If you want the K series CPU to be able to overclock properly (as the K is designed to do) you will need to make sure you purchase RAM of at least 1600 MHZ with heat sinks. It would pay to research this so you can ensure you purchase RAM that will be capable of overclocking.
Actually, you are incorrect. The whole reason behind the K series of chips is that the cpu multiplier is separated from the memory multiplier, meaning that the cpu can be overclocked without overclocking the memory. So, while agree that 1600 memory is nice, it's not a requirement for overclocking a K series chip.
