Checked some reviews on the PSU most of them saying they died so i would recommend to change PSU for an better one with them specs. Plus the specs will run fine since part picker says no issues. If you have budget and your friend only wants it for gaming then change 32GB ram into 16GB and get better PSU because it looks cheap and reviews are not good!
