Question will this build work down to compatibility and size fittings?
Nov 20, 2024
hi all I just wanted to ask for a straight forward answer here the build I sent in I wanted to see if it would have the size requirement for all the parts to fit into the case and should I be aware of any dimension problems outside that just want to check if there any compatibility issues that PC part picker is not picking up on that's why I asked here thank you
build here
so is that meaning everything checks out and you see nothing very or something else can you clarify? I'm just kind of looking for a yes or no answer in the matter because I'm going to be getting it very soon I just want to see if there's any catastrophic issues with the thing or that it's a fine build and it will work as intended
In a very quick look, the only thing that stands out to me is to check that the CPU cooler isn't taller than the case width will allow.
You might consider checking price on a WD Black for the M.2 as it is a bit faster and fairly competitive pricing. Nothing at all wrong with the P3 Plus. I use them in a few of my current builds and have had no issue.
Do you have any additional fans considered at first? Perhaps a good idea to see how thermals are before adding to the fan count.
Lastly, you will need more than 1TB storage. In particular if you are gaming. Modern games take up so much room...
agreed with the RAM and I don't believe I've seen pictures of people with chunkier and wider CPU fans SO ill say it'd be fine completely agree with you on the SSD I changed it out to 2tb and I saw it was a lot more competitive here's the one I'm getting https://www.amazon.de/-/en/gp/product/B09QV5KJHV/ref=ox_sc_act_title_2?smid=A3JWKAKR8XB7XF&th=1
and for the fan situation I believe it comes with 4 I saw people on the Amazon description talk about it
I'll get it in first and I'll see if I need to add any additional fans but I can cannibalise two off my old build that i dont use
