Will this Card work with this Power supply?
my5thbebo
9
Asus Cerberus gtx1050ti 4gb
fsp hyper m 600w power supply
Was about to purchase both but noticed that in the product information for the PSU it says "PCI-Express 6+2 Pin Connectors for VGA Card". The graphics card doesn't have a VGA slot so will these items not work together?
Hi
according to Asus website this GPU card does not need a PCI-e power connection
(so it takes its power from the PCI-e slot)
PCI-Express 6+2 Pin Connectors for VGA card is a generic term for any PCI-e Graphics card it does not mean VGA resolution or VGA 15 pin
connector
There are better quality PSU available but if it is a genuine 600W PSU it should be OK
regards
Mike Barnes
Hi
connector
regards
Mike Barnes
Your PSU choice is a decent one and far exceeds the requirements to run a 1050ti. :)
