[SOLVED] will this combination of parts work?
Try using PCPartpicker to spec your system, it'll highlight compatibility issues and give you a good idea of price as well. Without knowing your budget and what you want to do (gaming, work, etc) it's hard to spec a system but here's a starter for ten:
PCPartPicker Part List: https://uk.pcpartpicker.com/list/HMs83t
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor (£198.94 @ CCL Computers)
Motherboard: Gigabyte B450 AORUS ELITE ATX AM4 Motherboard (£94.97 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£78.73 @ Amazon UK)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive (£59.12 @ CCL Computers)
Video Card: MSI Radeon RX 5700 8 GB GAMING X Video Card (£309.99 @ CCL Computers)...
The Thermaltake TR2 PSU is awful and a surefire way to destroy one of your components when it dies. I'd replace that with a Corsair CX 550 2017 (non modular) at least.
Reactions: Rdslw
3 things:
Replace that PSU with anything from t1 or t2 https://www.gamingscan.com/psu-hierarchy/ If you want to use it for more than 2 years.
I would pick cheaper CPU like Zen 3600 for it,
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-9700K-vs-AMD-Ryzen-5-3600/4030vs4040
As its basically same performance with that GPU but half $.
Ddr4 ram not ddr3. Its really worth it & DDR3 will not work after the Skylake series of processors.
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply (£69.98 @ Currys PC World Business)
Total: £811.73
Generated by PCPartPicker 2020-05-28 12:38 BST+0100
Total: £811.73
I would not use Corsair LPX memory with Ryzens.
Total: £811.73
thanks a lot! the details part on the page kind of confuses me, but this was by far the most helpful answer
