Will this cooler fit in my case?
Hi nicedude80
The coolermaster hyper 212 evo stands 159mm tall ,
The maximum supported cpu cooler height for the Cooler Master Elite 430 is 163mm
so yes it will fit in your case
EDIT: A better choice for overclocking at lower temperature than the evo is
the nazxt Havik 140mm , here is a review comparing it to the Noctua NHD14 this will not interfere with your ram either
https://www.youtube.com/watch?v=QuI5NLOpRmo
Thanks for the reply but is there any other coolers that are under $50? Also will the hyper 212 evo be adequate for lots of overclocking, because if so I will keep that unless there is a better one for under $50.
But how will they compare? Like will I be able to keep a 4690k under 50c at max oc? Or could any cooler even do that? What is the max temp for a CPU before it starts to damage it and decrease its life span?
Will I have a safe temp with the 212 though? Like cool enough so my processor doesn't start to burnout?
