D Deedop Reputable Jan 20, 2016 3 0 4,510 Apr 12, 2018 #1 Need to buy a CPU cooler for a new build but the only one I can find locally is a mysterious "xilence LGA B". This may be a stupid/obvious question but does this mean it will fit any LGA motherboard? Specifically, an LGA 1155 motherboard? Thanks
Solution Z Z zyh1987 Apr 12, 2018 is this the one? https://www.amazon.de/Xilence-10659-FROZEN-FIGHTER-COO-XPCPU-LGA-B-R2/dp/B002YCD2O8 looks like no, it only fit a lga 775, which is core 2 duo/quads CPU, generation before core i3/i5/i7 series.
Z zyh1987 Estimable Mar 16, 2018 2,146 9 3,065 Apr 12, 2018 Solution #2 is this the one? https://www.amazon.de/Xilence-10659-FROZEN-FIGHTER-COO-XPCPU-LGA-B-R2/dp/B002YCD2O8 looks like no, it only fit a lga 775, which is core 2 duo/quads CPU, generation before core i3/i5/i7 series. Upvote 1 Downvote Solution
T timothy273 Apr 12, 2018 14 0 40 Apr 12, 2018 #3 Are you talking about this one? https://www.amazon.co.uk/Xilence-COO-XPCPU-LGA-B-R2-Frozen-Fighter-775-R2/dp/B00LFM0B60 Upvote 0 Downvote
D Deedop Reputable Jan 20, 2016 3 0 4,510 Apr 12, 2018 #4 zyh1987 : is this the one? https://www.amazon.de/Xilence-10659-FROZEN-FIGHTER-COO-XPCPU-LGA-B-R2/dp/B002YCD2O8 looks like no, it only fit a lga 775, which is core 2 duo/quads CPU, generation before core i3/i5/i7 series. Damn alright thanks man Upvote 0 Downvote
