A Amin812 Reputable Jun 20, 2015 3 0 4,510 Jun 21, 2015 #1 Hello all, I wish to replace my stock cooler to Cooler Master Hyper 212 EVO My Case: NZXT H230 ATX Mid tower case Mobo: Asus M5A97 R2.0 Will it fit just right or will it fit barely? Thanks.
Solution A A ajitesh Jun 22, 2015 The clearance on your case is 158mm and the cooler is 159mm. A 1mm difference should not make a difference and it should fit fine.
A ajitesh Distinguished Jan 30, 2014 131 0 18,710 Jun 22, 2015 Solution #2 The clearance on your case is 158mm and the cooler is 159mm. A 1mm difference should not make a difference and it should fit fine. Upvote 0 Downvote Solution
