Will this liquid cooler fit in my s340?
ashleyyu12
For my PC build, I am thinking on getting a NZXT s340 mid-tower case and I am on a hunt for a good liquid cooling CPU. I have my eye on the Kraken x62 Rev 2 98.2 CFM Liquid CPU Cooler but I was wondering if it would fit in my case properly. If not, I would love more suggestions on some liquid coolers!
Or, should I go for the NZXT S340 Elite since it is a bit more roomier?
S340 should be fine, check https://www.google.com/search?q=nzxt+s340+kraken+x62+rev2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiLza7ytPXWAhXEKCYKHfnMAPYQ_AUICygC&biw=1920&bih=949#imgrc=3WCFYW8Ra2ldeM:
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler ($153.99 @ SuperBiiz)
Case: NZXT - S340 (Black) ATX Mid Tower Case ($64.99 @ SuperBiiz)
Total: $218.98
Generated by PCPartPicker 2017-10-16 11:02 EDT-0400
Total: $218.98
Yes it will fit perfectly well.
though I hope you understand that this wannabe liquid cooler shinny toy is just an expensive illumination as well as all crap made by asetek (http://www.asetek.com/desktop/do-it-yourself/). Any high end cooler from Noctua, Be Quiet, Cryorig will do same cooling at lower noise without reliability issues.
