Will this Liquid cooler fit?
MrLeeby
Commendable
Feb 4, 2017
139
Hi, I was thinking about buying the Corsair Hydro Series H55 for my CPU. Just wondering if it will fit in a case that has a maximum CPU cooler height of 125mm
Also, will it fit on a H110M-Pro-VD motherboard
thanks
Yes it will fit on the motherboard since that is an 1151 socket.
All you need to make sure of is that your case can fit the radiator and I cant answer that since you have not listed what kind of case you have.
Ah okay, Great!
thanks for all the help
