Will this PSU work with my build?
PeppermintFangs
378
My new PC build keeps crashing. Some people have suggested it's the power supply that's causing the problem, mainly because it's multi-rail rather than single-rail. However, after looking it up online, many other suggest this is hardly a factor. It's also worth mentioning that the system I have listed on my profile was run flawlessly by this power supply.
So I'll leave it to the community - do you guys think the EVGA Supernova NEX650W 80+ Gold Certified PSU is enough to run the configuration below? If not, and you think it's causing the crashes, what PSU (preferably under $80, but under $100 will do) do you suggest?
https://pcpartpicker.com/list/pC3NxY
Thanks in advance for your help!
Unfortunately this isn't an option given the crashes are occurring before I even have the chance to install windows. Windows 7 setup crashes, so I can't do any tests.
I can get into bios luckily, it's just booting windows that crashes the computer. I have tried one ram stick and that didn't work either.
Just bought a PSU that I've seen several other skylake builds use. A little painful for my wallet, as it was unplanned, but perhaps necessary. I'll update the thread with what will hopefully be my success. Thanks for your help!
