[SOLVED] Will this system i want to build work fine and fast enough and last a while and is completly compatable
I would highly recommend spending a little more on a system like this as it is substantially more powerful with much better cooling. The 5600g graphics performance is about 10% faster than a 1030. You can add in a much more powerful card later and the 5600g will not hold you back as a CPU. Also the motherboard comes with wireless / Bluetooth so no need to put an add-in card for it.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor (£220.79 @ Newegg UK)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler (£40.47 @ Scan.co.uk)
Motherboard: Gigabyte B550 AORUS ELITE AX ATX AM4 Motherboard (£99.98 @ Currys PC World Business)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (£64.99 @ Corsair UK)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (£68.98 @ Ebuyer)
Case: Corsair 4000D Airflow ATX Mid Tower Case (£64.98 @ AWD-IT)
Power Supply: EVGA G3 550 W 80+ Gold Certified Fully Modular ATX Power Supply (£69.98 @ Scan.co.uk)
Operating System: Microsoft Windows 10 Home OEM 64-bit (£86.99 @ AWD-IT)
Total: £717.16
Generated by PCPartPicker 2021-10-20 18:26 BST+0100
Reactions: punkncat
punkncat
Splendid
Ambassador
PCP is throwing some compatibility flags of it's own.
Would check the motherboard to be sure it is compatible with that Athlon without needing a BIOS update.
To be fair, I tried one of these Athlons for a file server. They are VERY anemic and I wouldn't suggest trying to utilize one for "future proof" work use over that period.
IDK what the landscape for refurbished office PC is in your area, but would suggest that a used Dell or HP enterprise level machine would be a great bet. It is not uncommon to be able to find 4th gen i5 based systems for ~$100 here. Budget an SSD and perhaps some memory if you don't buy it with. Should serve you well for several years to come.
Sep 15, 2021
36
My plan is if need be I can upgrade the cpu to newer athlons as time goes buy and the website says it is comptable but might need a bios upgrade
Total: £717.16
Reactions: punkncat
Limited space need the case size
This is a much smaller case. What are the dimensions you are trying to fit the computer into?
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler (£37.27 @ Overclockers.co.uk)
Motherboard: Asus PRIME B550M-A (WI-FI) Micro ATX AM4 Motherboard (£99.99 @ AWD-IT)
Case: Silverstone FARA H1M MicroATX Mini Tower Case (£50.47 @ Scan.co.uk)
Total: £699.46
Generated by PCPartPicker 2021-10-20 20:39 BST+0100
Or this for a better motherboard...
Motherboard: MSI MAG B550M MORTAR WIFI Micro ATX AM4 Motherboard (£131.06 @ Amazon UK)
Total: £730.53
Generated by PCPartPicker 2021-10-20 20:57 BST+0100
