Question Will Two 4x2 & Two 8x2 G.Skill Ripjaws V 2444mhz RAM work in dual channel mode?
darkerm
19
I have two 4gb G.Skill Ripjaws V 2444mhz RAM.
My Motherboard has 4 Ram slot.
I want to add more Ram.
I'm playing to buy Two 8gb same model same speed RAM.
So will it work in dual channel? Or they will work like single Chanel?
They will work in 2 x dual channel, provided they are set up correctly. Consult your motherboard manual how to place the RAM sticks. The RAM slots are sometimes colorcoded:
https://upload.wikimedia.org/wikipe...slots_–_dual_channel-top_oblique_PNr°0302.jpg
These aren't:
https://forums.tweaktown.com/attach...ram-dual-channel-970-extreme3-r2-0-a-dimm-jpg
In the top right however, you can see DDR3_A1, DDR3_A2, DDR3_B1 and DDR3_B2. A1 and B1 go together, just like how A2 and B2 go together. Check your motherboard manual for more, accurate info.
Reactions: darkerm
https://upload.wikimedia.org/wikipedia/commons/8/82/DDR3_RAM_slots_–_dual_channel-top_oblique_PNr°0302.jpg
These aren't:
Yes they are colored. Two black, two Green.
Motherboard Gigabyte Sniper g1 B7
Only the set of identical sticks will work as dual channel. The 8 GB would be added as standalone. There simply need to be 2 of the same kind to make use of dual channel.
Here is my mother board support lsit for ram. I also mark the ram model with red mark.
it stay memory socket support only 2? what does this means? can you please help me on this.
