G GoodaBrine XD Honorable Feb 11, 2016 250 0 10,790 Sep 10, 2016 #1 Will upgrading fix the problem? I only have a 70gb hdd though.
S ss202sl Glorious May 23, 2012 8,428 35 44,190 Sep 10, 2016 Solution #2 not if there is a physical HDD problem. how old is the drive? Upvote 0 Downvote Solution
G GoodaBrine XD Honorable Feb 11, 2016 250 0 10,790 Sep 10, 2016 #3 ss202sl : not if there is a physical HDD problem. how old is the drive? Pretty old, is there a way I can check? (I don't have any other HDD on me though) The BIOS still detects it, so yeah. Upvote 0 Downvote
S ss202sl Glorious May 23, 2012 8,428 35 44,190 Sep 11, 2016 #4 use a knoppix (or similar) cd to boot it. then you should be able to look at the hdd and see if there is anything salvageable. Upvote 0 Downvote
