Question Will USB Graphic Cards work for Multiple Display?
lakshminandankarri
35
Hello Experts,
I have a PC with the following components:
  1. AMD 5800x Processor
  2. MSI MPG X570 Gaming Plus Motherboard
  3. 64 GB RAM
I want a 6 Monitor Display for my Trading setup. I couldn't find GPU card for my PC with 6 Outputs.
So, Can I use Plugable USB Graphic Cards for my 6 Monitor Setup with a Plugable USB 3.0 ( 7 Port ) Hub?
Will it work? Does it cause any harm to my PC?
Plugable USB Graphic Card - Plugable USB 3.0 HDMI/DVI/VGA Adapter for Multiple Monitors – Plugable Technologies
Plugable USB Port Hub - USB 3.0 7-Port Hub with 2 BC 1.2 Charging Ports and 36W Power Adapter – Plugable Technologies ( 25 W )
Thanks in Advance. :)
might be a bit late on this one, but no
you can't just use a USB adapter to replace a GPU.
what i suggest doing instead is buying 2 used mid range GPUs and run both of it on SLI (or Crossfire) and have your displays connect that way
