Will using Intel's integrated graphics increase temperatures?
TheAJ
7
Hi,
I recently assembled a PC to get some hands on experience. I resolved most of my questions via searching Google (most of them were solved on this forum), but could not find a definite answer to my latest question; will using Intel's integrated graphics increase my CPU core temps?
I have a 4770k, but my question is generic towards all CPUs that have integrated graphics.
If I install a graphics card, which will (by what I understand) offload some operations to the GPU, will I see improved temperatures on my CPU?
At this moment, I do not have a graphics card (mainly to ensure that the rest of the system works and is stable before buying some extras such as the GPU, better fans, more HDDs, etc) so I am using the integrated graphics that comes with the haswell processors
My main use of this desktop will be programming/development.
Yes it does but the igpu is low power, 4w tdp, so it isn't much. You probably won't even see a difference.
Btw adding a graphics card doesn't offload some, the igpu gets disabled.
Installing a discrete GPU will indeed disable the iGPU as default, but you can enable it back via BIOS if you need it, e.g. if you want to connect another display or a TV set and your discrete GPU doesn't have the right port.
I too have a 4770k and just noticed that by taking out the discrete GPU (I had an Asus GTX 650 with 2GB DDR5), the CPU runs cooler at 25 - 35° Celsius, as opposed to 35 - 50° Celsius I had when the GTX 650 was installed and running.
And no noticeable difference in CPU temperature if the Intel iGPU was enabled or disabled.
