Do no read only that 'perfect'.
Post here the SMART report of your hard disk.
It could be perfect while there are actually reallocated or pending bad blocks.
Meanwhile from Command Dos (CMD) with Adrmin rights run the following command:
sfc /scannow
sfc /scannow has indicated that it did not find any integrity violations.
TEST REPORT:
Hard Disk Sentinel 5.40 PRO
(unregistered version)
Date and time: 2019-05-13 22:38:19
Install date : 2019-05-05 00:00:00
Health calculation method: Analyse data field (default) (1)
Command line: C:\Program Files (x86)\Hard Disk Sentinel\HDSentinel.exe
Operating System Information:
Name . . . . . . : Windows 8.1 [64bit]
Service Pack . . : None
Version . . . . : 6.3 Build: 9600
System Directory : C:\WINDOWS\system32
WindowsLanguage : polski
SystemDefaultLI : 0415
WinLanguage . . : Polski (Polska) [Polish]
HDDSelDB . . . . : 0
HDS Uptime . . . : 110
System Idle time2: 0
HDD Spin Down . : 0
Desktop size . . : 1600 x 900 (96 DPI)
HDS CFV . . . . : No 22:38:14 3,2 V:-1
GlobalTRIMStatus : DisableDeleteNotify = 0 //
Hard Disk Information:
1 drive(s) detected, largest index is: 0
Last Detection Errors:
#0: NONE RS:T DE:0 IS:0 T: 172 ms / Time: ATAID:34 AE ENABLE_SMART:1 SMART_THRESHOLDS:39 SMART_VALUES:93
Drive 0: WDC WD10JPVT-55A1YT0
Serial number . . . . : WD-WX61EC1XRX06
Revision . . . . . . : 01.01A01
Size . . . . . . . . : 931 GB
Temperature . . . . . : 36
Max. Temperature . . : 36 E:36
Max. Temp. by drive . : 37
Power on time . . . . : 546 days, 11 hours
Remaining lifetime . : more than 1000 days
Days d. by temperatute: 0
Power on time measure : [1]
Power state . . . . . : 1 / 2
Interface used . . . : S-ATA II
Instance ID . . . . . : SCSI\Disk&Ven_WDC&Prod_WD10JPVT-55A1YT0\4&484f6b&0&000000
Lifetime stats . . . : SS: 7425 WR: -1 BPS:512 TSEC:1953520065
TRMENA=0 1 N: 0
ATA control byte . . : Valid
ATA checksum value . : Valid
Attribute1V . . . . . : Yes OK L:
S.M.A.R.T. Parameters :
1 Raw Read Error Rate 51 200 200 000000000000 002F P H OK
3 Spin Up Time 21 179 175 0000000007E9 0027 P H OK
4 Start/Stop Count 0 93 93 000000001D01 0032 OK (Always passing)
5 Reallocated Sectors Count 140 200 200 000000000000 0033 H OK
7 Seek Error Rate 0 200 200 000000000000 002E P OK (Always passing)
9 Power On Time Count 0 83 83 00000000333B 0032 OK (Always passing)
10 Spin Retry Count 0 100 100 000000000000 0032 OK (Always passing)
11 Drive Calibration Retry Count 0 100 100 000000000000 0032 OK (Always passing)
12 Drive Power Cycle Count 0 93 93 000000001C29 0032 OK (Always passing)
191 G-Sense Error Rate 0 1 1 0000000000AB 0032 OK (Always passing)
192 Power off Retract Cycle Count 0 200 200 000000000086 0032 OK (Always passing)
193 Load/Unload Cycle Count 0 174 174 000000013B1C 0032 OK (Always passing)
194 Disk Temperature 0 111 101 000000251524 0022 OK (Always passing)
196 Reallocation Event Count 0 200 200 000000000000 0032 OK (Always passing)
197 Current Pending Sector Count 0 200 200 000000000000 0032 OK (Always passing)
198 Off-Line Uncorrectable Sector Count 0 100 253 000000000000 0030 OK (Always passing)
199 Ultra ATA CRC Error Count 0 200 200 000000000000 0032 OK (Always passing)
200 Write Error Rate 0 100 253 000000000000 0008 OK (Always passing)
254 Free Fall Event Count 0 1 1 0000000001D0 0032 OK (Always passing)
Disk Performance . . : 100 %
Disk Fitness . . . . : 100 %
S.M.A.R.T. Raw data :
0 0 8 67 1 123 3 0 1 0 2 187 5 0 0 0 0 0 0 0
S.M.A.R.T. Tests :
SelfTest1: None
SelfTest2: None
SelfTest3: None
IO information:
0000 28 00 00 00 48 01 00 00 00 00 00 01 00 00 00 00 (...H...........
0010 28 00 00 00 51 00 00 00 5A 00 00 00 0B 00 00 00 (...Q...Z.......
0020 00 00 00 00 00 00 00 00 57 44 43 20 57 44 31 30 ........WDC WD10
0030 4A 50 56 54 2D 35 35 41 31 59 54 30 00 00 00 00 JPVT-55A1YT0....
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 30 31 2E 30 31 41 30 31 00 20 20 20 20 20 57 .01.01A01. W
0060 44 2D 57 58 36 31 45 43 31 58 52 58 30 36 00 00 D-WX61EC1XRX06..
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
V/P: WDC WD10JPVT-55A1YT0
REV: 01.01A01
S/N: WD-WX61EC1XRX06
0000 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27 .../...........'
0010 00 B3 AF E9 07 00 00 00 00 00 04 32 00 5D 5D 01 ...........2.]].
0020 1D 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00 .......3........
0030 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32 ...............2
0040 00 53 53 3B 33 00 00 00 00 00 0A 32 00 64 64 00 .SS;3......2.dd.
0050 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00 .......2.dd.....
0060 00 00 0C 32 00 5D 5D 29 1C 00 00 00 00 00 BF 32 ...2.]]).......2
0070 00 01 01 AB 00 00 00 00 00 00 C0 32 00 C8 C8 86 ...........2....
0080 00 00 00 00 00 00 C1 32 00 AE AE 1C 3B 01 00 00 .......2....;...
0090 00 00 C2 22 00 6F 65 24 15 25 00 00 00 00 C4 32 ...".oe$.%.....2
00A0 00 C8 C8 00 00 00 00 00 00 00 C5 32 00 C8 C8 00 ...........2....
00B0 00 00 00 00 00 00 C6 30 00 64 FD 00 00 00 00 00 .......0.d......
00C0 00 00 C7 32 00 C8 C8 00 00 00 00 00 00 00 C8 08 ...2............
00D0 00 64 FD 00 00 00 00 00 00 00 FE 32 00 01 01 D0 .d.........2....
00E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0160 00 00 00 00 00 00 00 00 00 00 00 00 08 43 01 7B .............C.{
0170 03 00 01 00 02 BB 05 00 00 00 00 00 00 00 00 00 ................
0180 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6E ...............n
DBTY: 11
T: 404
Raw information:
0000 7A 42 FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00 zB.?7.......?...
0010 00 00 00 00 20 20 20 20 20 57 44 2D 57 58 36 31 .... WD-WX61
0020 45 43 31 58 52 58 30 36 00 00 00 40 00 00 30 31 EC1XRX06...@..01
0030 2E 30 31 41 30 31 57 44 43 20 57 44 31 30 4A 50 .01A01WDC WD10JP
0040 56 54 2D 35 35 41 31 59 54 30 20 20 20 20 20 20 VT-55A1YT0
0050 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80 ..
0060 00 00 00 2F 01 40 00 00 00 00 07 00 FF 3F 10 00 .../.@.......?..
0070 3F 00 10 FC FB 00 10 01 FF FF FF 0F 00 00 07 00 ?...............
0080 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 ..x.x.x.x.......
0090 00 00 00 00 00 00 1F 00 06 1F 04 00 4C 00 4C 00 ............L.L.
00A0 FE 01 00 00 6B 74 09 7D 23 61 69 74 09 BC 23 61 ....kt.}#ait..#a
00B0 7F 20 57 00 57 00 80 00 FE FF 00 00 00 00 00 00 W.W...........
00C0 00 00 00 00 00 00 00 00 B0 6D 70 74 00 00 00 00 .........mpt....
00D0 00 00 00 00 03 60 00 00 01 50 E6 4E 6D AD F7 2D .....`...P.Nm..-
00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 40 ...............@
00F0 18 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
0100 29 00 00 00 00 00 00 00 00 00 E8 16 00 00 00 00 )...............
0110 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 ................
0120 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 ................
0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190 00 00 00 00 00 00 00 00 00 00 00 00 B5 70 00 00 .............p..
01A0 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 ...@............
01B0 00 00 18 15 00 00 00 00 00 00 00 00 3E 10 00 00 ............>...
01D0 00 00 00 00 01 00 00 10 00 00 00 00 00 00 00 00 ................
01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 F1 ................
Partition Information:
0: C:
Volumes
0 GPT _ BA 2226126848 958209720320 2226126848 958209720320 233937919 C:\
0 GPT _ {DE94BBA4-06D1-4D40-A16A-BFD50179D6AC} 273678336 1545601024 273678336 1545601024 377343 Windows RE tools
0 GPT _ {DE94BBA4-06D1-4D40-A16A-BFD50179D6AC} 960435847168 472907776 960435847168 472907776 115455
0 GPT _ {DE94BBA4-06D1-4D40-A16A-BFD50179D6AC} 960908754944 39295385600 960908754944 39295385600 9593599 Recovery
Performance Information: 8 / 32
_Total
0 C:
T: 2 4 0 PerfMSMax: 5
Disk Information Reported By Operating System:
Name . . . . . . : \\.\PHYSICALDRIVE0
Description . . : Stacja dysków
Index . . . . . : 0
Interface Type . : IDE
Manufacturer . . : (Standardowe stacje dysków)
Media Type . . . : Fixed hard disk media
Model . . . . . : WDC WD10JPVT-55A1YT0
Partitions . . . : 6
PNPDeviceID . . : SCSI\DISK&VEN_WDC&PROD_WD10JPVT-55A1YT0\4&484F6B&0&000000
SCSI Bus . . . . : 0
SCSI Logical Unit: 0
SCSI Port . . . : 0
SCSI Target ID . : 0
Size . . . . . . : 1000202273280
Status . . . . . : OK
SCSI locations
PD0: Port:0 Target:0 Pathid:0 LUN:0
PNP Detect: WMI(1): 189 ms DCH+DNL(26,66): 204 ms
NVRAID:
Invalid class
Invalid class
Invalid class
Invalid class
Motherboard:
Name . . . . . . : VAIO
Manufacturer . . : Sony Corporation
Serial Number . : N/A
Driver Information
DISPLAY\AUO203E\4&37A5260C&8&UID67568640
6.3.9600.16384 6-21-2006 Generic PnP Monitor
DTSOFTBUS&REV1\DTCDROM&REV1\1&1A590E2C&0&00
6.3.9600.18878 6-21-2006 DTSOFT Virtual CdRom Device
HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_104D6200&REV_1000\4&69D8376&0&0001
6.0.1.6748 10-9-2012 Realtek High Definition Audio
HDAUDIO\FUNC_01&VEN_8086&DEV_2806&SUBSYS_104D6200&REV_1000\4&69D8376&0&0301
6.16.0.3154 9-9-2014 Intel(R) Display Audio
HID\SNYA008\5&16B7780F&0&0000
6.3.9600.19304 6-21-2006 HID-compliant wireless radio controls
HID\VID_0EEF&PID_7902&COL01\7&2E3941F5&0&0000
6.3.9600.19304 6-21-2006 HID-compliant touch screen
HID\VID_0EEF&PID_7902&COL02\7&2E3941F5&0&0001
6.3.9600.17808 6-21-2006 HID-compliant mouse
HID\VID_0EEF&PID_7902&COL03\7&2E3941F5&0&0002
6.3.9600.19304 6-21-2006 HID-compliant vendor-defined device
HID\VID_0EEF&PID_7902&COL04\7&2E3941F5&0&0003
6.3.9600.16384 6-21-2006 Microsoft Input Configuration Device
HID\VID_15D9&PID_0A4C\6&27F2EDB5&2&0000
PCI\VEN_10EC&DEV_8168&SUBSYS_9095104D&REV_07\4&30200ACB&0&00E2
8.60.1003.2017 10-3-2017 Realtek PCIe GBE Family Controller
PCI\VEN_1180&DEV_E232&SUBSYS_9095104D&REV_04\4&2088AA6B&0&01E1
6.20.13.30 7-20-2012 Ricoh PCIe Memory Stick Host Controller
PCI\VEN_1180&DEV_E823&SUBSYS_9095104D&REV_04\4&2088AA6B&0&00E1
6.20.13.42 7-10-2012 @oem14.inf,%R5U822Desc%;Ricoh PCIe SD Host Controller
PCI\VEN_168C&DEV_0032&SUBSYS_E044105B&REV_01\4&2AA97FFC&0&00E0
10.0.0.338 2-18-2016 Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
PCI\VEN_8086&DEV_0151&SUBSYS_9095104D&REV_09\3&11583659&0&08
10.1.1.40 1-3-2017 Xeon(R) processor E3 - 1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
PCI\VEN_8086&DEV_0154&SUBSYS_9095104D&REV_09\3&11583659&0&00
10.1.1.40 1-3-2017 Xeon(R) processor E3 - 1200 v2/3rd Gen Core processor DRAM Controller - 0154
PCI\VEN_8086&DEV_0166&SUBSYS_9096104D&REV_09\3&11583659&0&10
11.18.10.4358 5-30-2016 Intel(R) HD Graphics 4000
PCI\VEN_8086&DEV_1E03&SUBSYS_9095104D&REV_04\3&11583659&0&FA
12.8.0.1016 8-1-2013 Intel(R) 7 Series Chipset Family SATA AHCI Controller
PCI\VEN_8086&DEV_1E10&SUBSYS_9095104D&REV_C4\3&11583659&0&E0
10.1.1.40 1-3-2017 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
PCI\VEN_8086&DEV_1E12&SUBSYS_9095104D&REV_C4\3&11583659&0&E1
10.1.1.40 1-3-2017 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 2 - 1E12
PCI\VEN_8086&DEV_1E14&SUBSYS_9095104D&REV_C4\3&11583659&0&E2
10.1.1.40 1-3-2017 Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 3 - 1E14
PCI\VEN_8086&DEV_1E20&SUBSYS_9095104D&REV_04\3&11583659&0&D8
6.3.9600.17238 7-23-2014 High Definition Audio Controller
PCI\VEN_8086&DEV_1E22&SUBSYS_9095104D&REV_04\3&11583659&0&FB
16.2.16.2 9-27-2012 Synaptics SMBus Driver
PCI\VEN_8086&DEV_1E26&SUBSYS_9095104D&REV_04\3&11583659&0&E8
9.3.0.1030 7-31-2013 Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
PCI\VEN_8086&DEV_1E2D&SUBSYS_9095104D&REV_04\3&11583659&0&D0
9.3.0.1030 7-31-2013 Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
PCI\VEN_8086&DEV_1E31&SUBSYS_9095104D&REV_04\3&11583659&0&A0
6.3.9600.19026 4-28-2018 @System32\drivers\usbxhci.sys,#1073807361;%1 USB 3.0 eXtensible Host Controller - %2 (Microsoft);(Intel(R),0100)
PCI\VEN_8086&DEV_1E3A&SUBSYS_9095104D&REV_04\3&11583659&0&B0
11.0.5.1189 3-28-2016 Intel(R) Management Engine Interface
PCI\VEN_8086&DEV_1E59&SUBSYS_9095104D&REV_04\3&11583659&0&F8
10.1.1.40 1-3-2017 Intel(R) HM76 Express Chipset LPC Controller - 1E59
SCSI\CDROM&VEN_MATSHITA&PROD_DVD-RAM_UJ8C2\4&484F6B&0&040000
6.3.9600.18878 6-21-2006 MATSHITA DVD-RAM UJ8C2
6.3.9600.18758 6-21-2006 WDC WD10JPVT-55A1YT0
STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT1
6.3.9600.16384 6-21-2006 Generic volume shadow copy
STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT2
STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT3
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#0000000000100000
6.3.9600.18266 6-21-2006 Generic volume
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#0000000010500000
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#000000006C700000
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#000000007CB00000
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#0000000084B00000
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#000000DF9E700000
STORAGE\VOLUME\{1653CA6F-1CC6-11E6-BFE5-806E6F6E6963}#000000DFBAA00000
SWD\DAFUPNPPROVIDER\UUID:4D454930-0100-1000-8001-D8AFF18DD37B
6.3.9600.16384 6-21-2006 55EX600_Series
SWD\IP_TUNNEL_VBUS\IP_TUNNEL_DEVICE_ROOT
6.3.9600.16384 6-21-2006 @System32\iphlpsvc.dll,-504;Microsoft IPv4 IPv6 Transition Adapter Bus
SWD\IP_TUNNEL_VBUS\ISATAP_0
6.3.9600.16384 6-21-2006 Microsoft ISATAP Adapter #3
SWD\MMDEVAPI\{0.0.0.00000000}.{1AD57BC7-10DF-48AF-97CC-106780DF585B}
6.3.9600.16384 8-22-2013 Speaker/HP (Realtek High Definition Audio)
SWD\MMDEVAPI\{0.0.1.00000000}.{EBA4CABA-66BA-42EF-B4E7-36407026FF4A}
6.3.9600.16384 8-22-2013 Microphone (Realtek High Definition Audio)
SWD\MSDAS\{CE958E9A-424F-4C88-86F4-11314821E75A}
6.3.9600.16384 6-21-2006 Microsoft Device Association Root Enumerator
SWD\PRINTENUM\PRINTQUEUES
6.3.9600.16384 6-21-2006 Root Print Queue
SWD\PRINTENUM\{0AD85D16-5F12-4DDC-8C04-CED17949D10F}
6.3.9600.16384 6-21-2006 MS Publisher Color Printer
SWD\PRINTENUM\{9D7DBACD-D102-4149-B2DB-FFEC94371EAB}
6.3.9600.16384 6-21-2006 Fax
SWD\PRINTENUM\{A4A21B2D-9DE2-491B-BDF9-4357DF9031EC}
6.3.9600.16384 6-21-2006 Foxit Reader PDF Printer
SWD\PRINTENUM\{D943D8D8-F7EB-4400-8EEE-A8CFF8C894B5}
6.3.9600.16384 6-21-2006 Microsoft XPS Document Writer
USB\ROOT_HUB20\4&1EE07617&0
6.3.9600.19026 6-21-2006 USB Root Hub
USB\ROOT_HUB20\4&23ECF35D&0
USB\ROOT_HUB30\4&58CFBC9&0&0
6.3.9600.18088 10-10-2015 USB Root Hub (xHCI)
USB\VID_0489&PID_E036\ALASKA_DAY_2006
8.0.1.344 4-13-2015 Qualcomm Atheros AR3012 Bluetooth(R) Adapter
USB\VID_0EEF&PID_7902\6&32EBBFB1&0&1
6.3.9600.19304 6-21-2006 USB Input Device
USB\VID_15D9&PID_0A4C\5&6F73C6D&0&1
USB\VID_1BCF&PID_2C01&MI_00\7&1CC63EE2&0&0000
6.3.9600.17217 6-21-2006 USB2.0 Camera
USB\VID_1BCF&PID_2C01\6&32EBBFB1&0&3
6.3.9600.18814 6-21-2006 USB Composite Device
USB\VID_8087&PID_0024\5&102457A8&1&1
6.3.9600.18814 6-21-2006 Generic USB Hub
USB\VID_8087&PID_0024\5&21F33243&1&1
{5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_SAP\5&2012D424&0&03
6.3.9600.16384 6-21-2006 Microsoft Hosted Network Virtual Adapter
{5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&2012D424&0&02
6.3.9600.16384 6-21-2006 Microsoft Wi-Fi Direct Virtual Adapter
Tray icon
TrayIconDef: 0-S0-S49S-T36
TrayIconMode: 1 FRem: 1
Info: ADD: Dysk: #0 - WDC WD10JPVT-55A1YT FL: 47 0 170
-- Formatted report --
-- General Information --
Application Information
Installed Version . . . . . . . . . . . . . . . : Hard Disk Sentinel 5.40 PRO
Registered To . . . . . . . . . . . . . . . . . : Unregistered version, please register.
Current Date And Time . . . . . . . . . . . . . : 2019-05-13 22:38:21
Health Calculation Method . . . . . . . . . . . : Analyse data field (default)
Computer Information
Computer Name . . . . . . . . . . . . . . . . . : KOWALSKICORP
User Name . . . . . . . . . . . . . . . . . . . : aircraftman3
Computer Type . . . . . . . . . . . . . . . . . : Mobile
IP Address . . . . . . . . . . . . . . . . . . . : 192.168.0.31
MAC Address . . . . . . . . . . . . . . . . . . : 08-3E-8E-B6-09-9F
System Uptime . . . . . . . . . . . . . . . . . : 0 days, 2 hours, 41 minutes, 9 seconds
System Idle Time . . . . . . . . . . . . . . . . : 0 days, 0 hours, 0 minutes, 0 seconds
System Up Since . . . . . . . . . . . . . . . . : 2019-05-13 19:57:12
CPU Usage . . . . . . . . . . . . . . . . . . . : CPU #1: 9 %, CPU #2: 20 %, CPU #3: 11 %, CPU #4: 9 %, CPU #5: 11 %, CPU #6: 11 %, CPU #7: 9 %, CPU #8: 10 %
Virtual Memory . . . . . . . . . . . . . . . . . : 12864 MB, Used: 5364 MB (42 %)
System Information
Windows Version . . . . . . . . . . . . . . . . : Windows 8.1
CPU Type & Speed #1 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #2 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #3 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #4 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #5 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #6 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #7 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
CPU Type & Speed #8 . . . . . . . . . . . . . . : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz, 2195 MHz
BIOS Manufacturer . . . . . . . . . . . . . . . : AMI
Physical Memory Size . . . . . . . . . . . . . . : 8064 MB, Used: 3575 MB (44 %)
Display Adapter . . . . . . . . . . . . . . . . : AMD Radeon HD 7600M Series
Display Resolution . . . . . . . . . . . . . . . : 1600 x 900 (32 bit)
Printer #1 . . . . . . . . . . . . . . . . . . . : Fax
Printer #2 . . . . . . . . . . . . . . . . . . . : Foxit Reader PDF Printer
Printer #3 . . . . . . . . . . . . . . . . . . . : Microsoft XPS Document Writer
Printer #4 . . . . . . . . . . . . . . . . . . . : MS Publisher Color Printer
Network Controller #1 . . . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Network Controller #2 . . . . . . . . . . . . . : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
Optical Drive #1 . . . . . . . . . . . . . . . . : D: MATSHITA DVD-RAM UJ8C2 / 1.00 (DVD-RAM, DVD-RW, CD-RW)
Optical Drive #2 . . . . . . . . . . . . . . . . : E: DTSOFT BDROM / 1.05 (CD)
PCI Device Information
PCI Bus 0; Device 1; Function 0 . . . . . . . . : Xeon(R) processor E3 - 1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
PCI Bus 0; Device 2; Function 0 . . . . . . . . : Intel(R) HD Graphics 4000
PCI Bus 0; Device 20; Function 0 . . . . . . . . : %1 USB 3.0 eXtensible Host Controller - %2 (Microsoft);(Intel(R),0100)
PCI Bus 0; Device 22; Function 0 . . . . . . . . : Intel(R) Management Engine Interface
PCI Bus 0; Device 26; Function 0 . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
PCI Bus 0; Device 27; Function 0 . . . . . . . . : High Definition Audio Controller
PCI Bus 0; Device 28; Function 0 . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
PCI Bus 0; Device 28; Function 1 . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 2 - 1E12
PCI Bus 0; Device 28; Function 2 . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 3 - 1E14
PCI Bus 0; Device 29; Function 0 . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
PCI Bus 0; Device 31; Function 2 . . . . . . . . : Intel(R) 7 Series Chipset Family SATA AHCI Controller
PCI Bus 0; Device 31; Function 3 . . . . . . . . : Synaptics SMBus Driver
PCI Bus 1; Device 0; Function 0 . . . . . . . . : AMD Radeon HD 7600M Series
PCI Bus 2; Device 0; Function 0 . . . . . . . . : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
PCI Bus 3; Device 0; Function 0 . . . . . . . . : Ricoh PCIe SD Host Controller
PCI Bus 3; Device 0; Function 1 . . . . . . . . : Ricoh PCIe Memory Stick Host Controller
PCI Bus 4; Device 0; Function 0 . . . . . . . . : Realtek PCIe GBE Family Controller
-- Physical Disk Information - Disk: #0: WDC WD10JPVT-55A1YT0 --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 0
Interface . . . . . . . . . . . . . . . . . . . : S-ATA II
Disk Controller . . . . . . . . . . . . . . . . : Intel(R) 7 Series Chipset Family SATA AHCI Controller (AHCI) [VEN: 8086, DEV: 1E03] Version: 12.8.0.1016, 8-1-2013
Disk Location . . . . . . . . . . . . . . . . . : Bus Number 0, Target Id 0, LUN 0
Hard Disk Model ID . . . . . . . . . . . . . . . : WDC WD10JPVT-55A1YT0
Firmware Revision . . . . . . . . . . . . . . . : 01.01A01
Hard Disk Serial Number . . . . . . . . . . . . : WD-WX61EC1XRX06
Total Size . . . . . . . . . . . . . . . . . . . : 953867 MB
Power State . . . . . . . . . . . . . . . . . . : Active
Logical Drive(s) . . . . . . . . . . . . . . . . : C: []
Current Temperature . . . . . . . . . . . . . . : 36 °C
Power On Time . . . . . . . . . . . . . . . . . : 546 days, 11 hours
Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
Health . . . . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
Performance . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
No actions needed.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . : 1938021
Hard Disk Heads . . . . . . . . . . . . . . . . : 16
Hard Disk Sectors . . . . . . . . . . . . . . . : 63
ATA Revision . . . . . . . . . . . . . . . . . . : ATA8-ACS
Transport Version . . . . . . . . . . . . . . . : SATA Rev 3.0
Total Sectors . . . . . . . . . . . . . . . . . : 244190646
Bytes Per Sector . . . . . . . . . . . . . . . . : 4096 [Advanced Format]
Buffer Size . . . . . . . . . . . . . . . . . . : 8192 KB
Multiple Sectors . . . . . . . . . . . . . . . . : 16
Error Correction Bytes . . . . . . . . . . . . . : 0
Unformatted Capacity . . . . . . . . . . . . . . : 953870 MB
Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
Maximum Multiword DMA Mode . . . . . . . . . . . : 2
Highest Possible Transfer Rate . . . . . . . . . : S-ATA II Signaling Speed (3 Gps)
Negotiated Transfer Rate . . . . . . . . . . . . : S-ATA II Signaling Speed (3 Gps)
Minimum Multiword DMA Transfer Time . . . . . . : 120 ns
Recommended Multiword DMA Transfer Time . . . . : 120 ns
Minimum PIO Transfer Time Without IORDY . . . . : 120 ns
Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
ATA Control Byte . . . . . . . . . . . . . . . . : Valid
ATA Checksum Value . . . . . . . . . . . . . . . : Valid
Acoustic Management Configuration
Acoustic Management . . . . . . . . . . . . . . : Not supported
Acoustic Management . . . . . . . . . . . . . . : Disabled
Current Acoustic Level . . . . . . . . . . . . . : Default (00h)
Recommended Acoustic Level . . . . . . . . . . . : Default (00h)
ATA Features
Read Ahead Buffer . . . . . . . . . . . . . . . : Supported, Enabled
DMA . . . . . . . . . . . . . . . . . . . . . . : Supported
Ultra DMA . . . . . . . . . . . . . . . . . . . : Supported
S.M.A.R.T. . . . . . . . . . . . . . . . . . . . : Supported
Power Management . . . . . . . . . . . . . . . . : Supported
Write Cache . . . . . . . . . . . . . . . . . . : Supported
Host Protected Area . . . . . . . . . . . . . . : Supported
HPA Security Extensions . . . . . . . . . . . . : Supported
Advanced Power Management . . . . . . . . . . . : Supported, Enabled
Advanced Power Management Level . . . . . . . . : Minimum power consumption without standby (128)
Extended Power Management . . . . . . . . . . . : Not supported
Power Up In Standby . . . . . . . . . . . . . . : Not supported
48-Bit LBA Addressing . . . . . . . . . . . . . : Supported
Device Configuration Overlay . . . . . . . . . . : Supported
IORDY Support . . . . . . . . . . . . . . . . . : Supported
Read/Write DMA Queue . . . . . . . . . . . . . . : Not supported
NOP Command . . . . . . . . . . . . . . . . . . : Supported
Trusted Computing . . . . . . . . . . . . . . . : Not supported
64-Bit World Wide ID . . . . . . . . . . . . . . : 50014EE6AD6D2DF7
Streaming . . . . . . . . . . . . . . . . . . . : Not supported
Media Card Pass Through . . . . . . . . . . . . : Not supported
General Purpose Logging . . . . . . . . . . . . : Supported
Error Logging . . . . . . . . . . . . . . . . . : Supported
CFA Feature Set . . . . . . . . . . . . . . . . : Not supported
CFast Device . . . . . . . . . . . . . . . . . . : Not supported
Long Physical Sectors (8) . . . . . . . . . . . : Supported
Long Logical Sectors . . . . . . . . . . . . . . : Not supported
Write-Read-Verify . . . . . . . . . . . . . . . : Not supported
NV Cache Feature . . . . . . . . . . . . . . . . : Not supported
NV Cache Power Mode . . . . . . . . . . . . . . : Not supported
NV Cache Size . . . . . . . . . . . . . . . . . : Not supported
Free-fall Control . . . . . . . . . . . . . . . : Not supported
Free-fall Control Sensitivity . . . . . . . . . : Not supported
Service Interrupt . . . . . . . . . . . . . . . : Not supported
IDLE IMMEDIATE Command With UNLOAD Feature . . . : Supported
Nominal Media Rotation Rate . . . . . . . . . . : 5400 RPM
SSD Features
Data Set Management . . . . . . . . . . . . . . : Not supported
TRIM Command . . . . . . . . . . . . . . . . . . : Not supported
Deterministic Read After TRIM . . . . . . . . . : Not supported
Read Zeroes After TRIM . . . . . . . . . . . . . : Not supported
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . : Never Started
Self Test Execution Status . . . . . . . . . . . : Successfully Completed
Total Time To Complete Off-line Data Collection : 17160 seconds
Execute Off-line Immediate . . . . . . . . . . . : Supported
Abort/restart Off-line By Host . . . . . . . . . : Not supported
Off-line Read Scanning . . . . . . . . . . . . . : Supported
Short Self-test . . . . . . . . . . . . . . . . : Supported
Extended Self-test . . . . . . . . . . . . . . . : Supported
Conveyance Self-test . . . . . . . . . . . . . . : Supported
Selective Self-Test . . . . . . . . . . . . . . : Supported
Save Data Before/After Power Saving Mode . . . . : Supported
Enable/Disable Attribute Autosave . . . . . . . : Supported
Error Logging Capability . . . . . . . . . . . . : Supported
Short Self-test Estimated Time . . . . . . . . . : 2 minutes
Extended Self-test Estimated Time . . . . . . . : 187 minutes
Conveyance Self-test Estimated Time . . . . . . : 5 minutes
Last Short Self-test Result . . . . . . . . . . : Never Started
Last Short Self-test Date . . . . . . . . . . . : Never Started
Last Extended Self-test Result . . . . . . . . . : Never Started
Last Extended Self-test Date . . . . . . . . . . : Never Started
Last Conveyance Self-test Result . . . . . . . . : Never Started
Last Conveyance Self-test Date . . . . . . . . . : Never Started
Security Mode
Security Mode . . . . . . . . . . . . . . . . . : Supported
Security Erase . . . . . . . . . . . . . . . . . : Supported
Security Erase Time . . . . . . . . . . . . . . : 174 minutes
Security Enhanced Erase Feature . . . . . . . . : Supported
Security Enhanced Erase Time . . . . . . . . . . : 174 minutes
Security Enabled . . . . . . . . . . . . . . . . : No
Security Locked . . . . . . . . . . . . . . . . : No
Security Frozen . . . . . . . . . . . . . . . . : Yes
Security Counter Expired . . . . . . . . . . . . : No
Security Level . . . . . . . . . . . . . . . . . : High
Device Encrypts All User Data . . . . . . . . . : No
Sanitize . . . . . . . . . . . . . . . . . . . . : Not supported
Overwrite . . . . . . . . . . . . . . . . . . . : Not supported
Crypto Scramble . . . . . . . . . . . . . . . . : Not supported
Block Erase . . . . . . . . . . . . . . . . . . : Not supported
Sanitize Antifreeze Lock . . . . . . . . . . . . : Not supported
ACS-3 Commands Allowed By Sanitize . . . . . . . : No
Serial ATA Features
S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
S-ATA I Signaling Speed (1.5 Gps) . . . . . . . : Supported
S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Not supported
Receipt Of Power Management Requests From Host . : Supported
PHY Event Counters . . . . . . . . . . . . . . . : Supported
Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
DMA Setup Auto-Activate Optimization . . . . . . : Supported, Enabled
Device Initiating Interface Power Management . . : Supported, Enabled
In-Order Data Delivery . . . . . . . . . . . . . : Not supported
Asynchronous Notification . . . . . . . . . . . : Not supported
Software Settings Preservation . . . . . . . . . : Supported, Enabled
Native Command Queuing (NCQ) . . . . . . . . . . : Supported
Queue Length . . . . . . . . . . . . . . . . . . : 32
NCQ Streaming . . . . . . . . . . . . . . . . . : Not supported
NCQ Autosense . . . . . . . . . . . . . . . . . : Not supported
Automatic Partial To Slumber Translations . . . : Not supported
Rebuild Assist . . . . . . . . . . . . . . . . . : Not supported
Hybrid Information . . . . . . . . . . . . . . . : Not supported
Device Sleep (DevSleep) . . . . . . . . . . . . : Not supported
DevSleep To ReducedPwrState . . . . . . . . . . : Not supported
Disk Information
Disk Family . . . . . . . . . . . . . . . . . . : Scorpio Blue
Form Factor . . . . . . . . . . . . . . . . . . : 2.5"
Capacity . . . . . . . . . . . . . . . . . . . . : 1 TB (1 x 1 000 000 000 000 bytes)
Number Of Disks . . . . . . . . . . . . . . . . : 2
Number Of Heads . . . . . . . . . . . . . . . . : 4
Rotational Speed . . . . . . . . . . . . . . . . : 5400 RPM
Rotation Time . . . . . . . . . . . . . . . . . : 11,11 ms
Average Rotational Latency . . . . . . . . . . . : 5,56 ms
Disk Interface . . . . . . . . . . . . . . . . . : Serial-ATA/300
Buffer-Host Max. Rate . . . . . . . . . . . . . : 300 MB/seconds
Drive Ready Time (Typical) . . . . . . . . . . . : 3.5 seconds
Average Seek Time . . . . . . . . . . . . . . . : ? ms
Track To Track Seek Time . . . . . . . . . . . . : ? ms
Full Stroke Seek Time . . . . . . . . . . . . . : ? ms
Width . . . . . . . . . . . . . . . . . . . . . : 69,9 mm (2,8 inch)
Depth . . . . . . . . . . . . . . . . . . . . . : 100,2 mm (3,9 inch)
Height . . . . . . . . . . . . . . . . . . . . . : 9,5 mm (0,4 inch)
Weight . . . . . . . . . . . . . . . . . . . . . : 120 grams (0,3 pounds)
Acoustic (Idle) . . . . . . . . . . . . . . . . : 2,4 Bel
Acoustic (Min Performance And Volume) . . . . . : 2,5 Bel
Acoustic (Max Performance And Volume) . . . . . : 2,5 Bel
Required Power For Spinup . . . . . . . . . . . : 975 mA
Power Required (Seek) . . . . . . . . . . . . . : 1,4 W
Power Required (Idle) . . . . . . . . . . . . . : 0,6 W
Power Required (Standby) . . . . . . . . . . . . : 0,2 W
Manufacturer . . . . . . . . . . . . . . . . . . : Western Digital Corporation
Manufacturer Website . . . . . . . . . . . . . . :
http://www.westerndigital.com/en/products
S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 51 200 200 000000000000 OK Self Preserving, Error-Rate, Performance, Statistica..
3 Spin Up Time 21 179 175 0000000007E9 OK Self Preserving, Performance, Statistical, Critical
4 Start/Stop Count 0 93 93 000000001D01 OK (Always passing) Self Preserving, Event Count, Statistical
5 Reallocated Sectors Co.. 140 200 200 000000000000 OK Self Preserving, Event Count, Statistical, Critical
7 Seek Error Rate 0 200 200 000000000000 OK (Always passing) Self Preserving, Error-Rate, Performance, Statistical
9 Power On Time Count 0 83 83 00000000333B OK (Always passing) Self Preserving, Event Count, Statistical
10 Spin Retry Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
11 Drive Calibration Retr.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
12 Drive Power Cycle Count 0 93 93 000000001C29 OK (Always passing) Self Preserving, Event Count, Statistical
191 G-Sense Error Rate 0 1 1 0000000000AB OK (Always passing) Self Preserving, Event Count, Statistical
192 Power off Retract Cycl.. 0 200 200 000000000086 OK (Always passing) Self Preserving, Event Count, Statistical
193 Load/Unload Cycle Count 0 174 174 000000013B1C OK (Always passing) Self Preserving, Event Count, Statistical
194 Disk Temperature 0 111 101 000000251524 OK (Always passing) Self Preserving, Statistical
196 Reallocation Event Count 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
197 Current Pending Sector.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
198 Off-Line Uncorrectable.. 0 100 253 000000000000 OK (Always passing) Self Preserving, Event Count
199 Ultra ATA CRC Error Co.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
200 Write Error Rate 0 100 253 000000000000 OK (Always passing) Error-Rate
254 Free Fall Event Count 0 1 1 0000000001D0 OK (Always passing) Self Preserving, Event Count, Statistical
Transfer Rate Information
Total Data Read . . . . . . . . . . . . . . . . : 92 MB, 92 MB since installation (2019-05-05)
Total Data Write . . . . . . . . . . . . . . . . : 186 MB, 186 MB since installation
Average Reads Per Day . . . . . . . . . . . . . : 11,50 MB
Average Writes Per Day . . . . . . . . . . . . . : 23,25 MB
Current Transfer Rate . . . . . . . . . . . . . : 2343 KB/s
Maximum Transfer Rate . . . . . . . . . . . . . : 25263 KB/s
Current Read Rate . . . . . . . . . . . . . . . : 296 KB/s
Current Write Rate . . . . . . . . . . . . . . . : 2047 KB/s
Current Disk Activity . . . . . . . . . . . . . : 100 %
-- Partition Information --
Logical Drive Total Space Free Space Free Space Used Space
C: (Disk: #0) 892,4 GB 110,7 GB 12 % #################---
